Both of my low beams stopped working at the same time. The high beams work. When I pull the directional stalk, it appears that both beams go on (it always did this and I think this is supposed to happen) and then when I let go it toggles to either high or low. Fuses are good. The relay clicks, however I will test it.
If the relay is clicking, can I assume the switch in the steering column is functioning correctly? That switch only sends power (monentarily) to the relay and changes the 12v output from terminal F to terminal 56a (or vice versa), right?
