My Harbor Freight $12.99 HVLP paint gun experience ended abruptly...I guess I wanted to believe I could do a good paint job with it. After shooting primer & paint in the engine bay, I was feeling decent about it. Plan was to use one gun for primer and one for paint. Screwed around a while with this.
Problems I had on a test panel:
The 1.4 mm tip that comes with the gun will clog with primer and create a rough finish. Ordered the 1.7 mm and 2.0 mm tips, waited 10 days, tested the 2.0 tip and found it was the wrong size.
Pressed on with the 1.7mm tip. Was able to lay down smooth coats of primer that required minimal sanding to make the surface smooth.
I was able to lay down a nice finish with the 1.4 mm tip, but continually had problems with fish-eye.
Take both guns apart and thoroughly clean them yet again, then talked to Zach. Added two water separators to the compressor and line and bought a brand new compressor hose.
With everything set up, I try again. Running solvent through the gun, I couldn't get an even spray...the gun threw out pulses of solvent. At this point, I had enough.
Bought a nice HVLP setup from Eastwood. My compressor didn't have the SCFM to run some of the recommended guns, putting out only 6.5 @ 40 PSI.
http://www.eastwood.com/ew-concours-primer...ips-2-cups.htmlWith the first attempt, I was able to lay down a nice finish, with one tiny fish-eye in a 2' X 2' panel.
In summary, I would probably use one of the HF $12.99 HVLP paint gun to paint a fence or something like that, but not a car. I would consider using it for engine bays as well. I could never get rid of fish-eye even after thoroughly cleaning the guns multiple times and adding two water separators. Plus, cleaning them is a chore and I found them to be somewhat unreliable.
Maybe someone with a better compressor/dryer setup could make it work, but I gave up.
