Hi Carl,
Not a dumb question!
If they're stock 914 transaxles, 5th gear is a ZD gearset (31 teeth/22 teeth. 0.71 ratio), versus what I want to get: a flipped HB (31/19, 0.61) or flipped H (32/19, 0.59). For me, a flipped H will lower cruising revs at 80 mph to about 3200 rpm, versus about 4000 now. As I understand it, all 4-cylinder 914s throughout the production run had ZD gears for 5th.
The H and HB gears come out of other variants of the 901 transaxle as fitted to 911s (and possibly 912s). It's so cool that many of the gearsets interchange, so you can mix and match. But apparently not the HA.
The flipped 5th makes sense for a big, torquey water-cooled V-8, not so much for a 90-bhp air-cooled flat-4, for a couple of reasons: the flat-4 doesn't really have enough torque to carry that tall of a 5th gear, and it's beneficial to spin the air-cooled engine a little faster at freeway speeds, to keep the fan speed up and enhance cooling.
--Doug
