Gang,
This is (
in my opinion) the BEST way to strip a chassis. PERIOD. Way to go William
I just spent about an hour looking over a friends chassis that was acid dipped. I had a 911 chassis acid dipped about 15 years ago. Here's what I've seen and experienced (real world gang):
1.
You can't neutrilize or get rid of all of the acid. Period. There are areas on any Karman style uni-body tub that will retain the acid. Two years "after" the dipping my 911 tub was weeping acid. The tub I just went and looked at is doing the "exact" same thing. (careful in your critique Norcals... it was done
there). Nothing against the firm doing it, they did an excellent job and the primer work was stunning... it's just a simple fact. There is acid weeping from almost all the seams. The bolt hole where you bolt on the front bumper? There's a couple of layers of metal sandwiched together there... weeping. There's a piece spot-welded in the passengers foot-well area before the bulkhead is welded in (meaning there's no way to access it)... weeping. What happens when acid weeps? It rusts the metal around it. Can you clean it up? Most of it by... BLASTING (can you imagine getting some sandpaper on that 1/16th of an inch of overlay on a seam?) You'll never get all of it.
2.
What do you have to do if you dip a tub? Get the heater tubes out... right? How do you get the heater tubes out? Cut open the longitudinals. What is the "backbone" of a 914 chassis? The longitudinal. Are you willing to have MAJOR back surgery so you can get a facelift? "If" your longitudinals are toast and you don't mind acid weeping out of your car (and you've got the extra dough... see my next point) then maybe acid dipping is right for you. You're going to slice the bottom of you long. right under the door. You're going to slice up the sides. You're going to peel up your long. like a tuna can to get to the tubes (remember, this is the backbone of your 914). Are you going to weld it back in when you're done? Let me give you a clue. No. It's pretty much toast after that (why? considering the task ahead of you... bent metal, cuts, but welds on major structural components etc. It's cheaper and better to get new ones and properly weld them in). Add a couple of outer rocker and door sill kits to the price of your project.
3.
Price. My friend paid $3,500 or more of his hard earned buck-a-roos to have the car acid dipped (not counting the metal work needed to repair the longs. after the back surgery). I paid $900 back in the late 80's (they didn't give a shit about tar paper and seam sealer back then). I think I remember William stating $1,000.00 Well worth it in the grand scheme of a proper restoration. It's worth 3x that.
Media blasting when done right will get you the desired results. Yes, sand blasting can warp panels if done at the wrong pressure etc. Walnut and plastic media are awesome. Soda can be hard to find do to the nature of the machinery needed (soda needs to be fed into the machine, not gravity feed) but if you can find one in your area, it's awesome. I'd rather spill a little sand around turn 4 at the autocross for a couple of years than have acid weeping on to my new paint for a couple of years.
If you're
not doing a ground up restoration don't worry about it. If you are... please (for the sake of these cars and your wallet) consider those facts.
My $0.02 now donning my baking soda flame suit (baking soda is good at putting out fires isn't it?) for the acid heads out there.
