veedubPORSCHEchris
Nov 10 2004, 04:20 PM
i have a 73 2L with the d jet fi is it hard to convert the 2L to cis?did a 14 ever come with cis?pros cons d vs cis
thanks in advance for the input
cheers
chris
Root_Werks
Nov 10 2004, 04:32 PM
I have heard and even seen one (years ago) where someone took parts from a VW Rabbit or whatever and had a nice CIS system on a Type4 2.0. He liked it, said it was a little more tunable and produced more power. Sure it can be done, but for the cost and work involved, I would go with a Mega Squirt system. More power and probably not all that much more money.
veedubPORSCHEchris
Nov 10 2004, 04:39 PM
never heard of the mega squirt is it like sds?i happened to have a crap load and a half of cis. the only reason i ask is my fi is not working right so i figured i would go with what i know. hmm now the wheels are turning, i like the idea of cis over carbs.perhaps that will be the route ill take.
any other thoughts on the subject?
chris
Nov 10 2004, 04:43 PM
QUOTE(veedubPORSCHEchris @ Nov 10 2004, 03:39 PM)
megasquirt is probably the cheapest solution, but you have to build it on your own ...
http://www.bgsoflex.com/megasquirt.htmlthe Kit Carlson FI will be a nice bolt-on package once it's completed ...
http://www.aircooledtechnology.com/kitcarlson.htm Andy
Dave_Darling
Nov 10 2004, 05:34 PM
Ed V put CIS on his 914 before he turbo'd it. He used the Miller FI setup.
http://www.sandrail.com/millerfi/EJM914 did a home-brew CIS for his 914 turbo install as well.
--DD
Mike D.
Nov 10 2004, 05:41 PM
Wasn't there someone who used a CIS from an older Volvo. I think I remember the Volvo was a 1.9 engine?
I could have been high
-Mike D.
gregrobbins
Nov 10 2004, 06:25 PM
Well, before you give up on you stock FI system, check out your injectors and make sure your hoses are not leaking, clean your electrical connections, and basic stuff like that.
But if you want to play around and maybe dig up a little more power, have fun and let us know how it is going. Gerard, a local Phoenix owner, went with Megasquirt with good success. He also went with a new cam at the same time and he has a STRONG 2.0
