1) I have searched around for a torque setting to install new step studs for the exhaust manifold/header. The only setting I can find is from Tunacan.net.
They list - heat exchangers to cylinder head at 16 ftlbs.
Does this apply to installing the stud in the case, the nut on the stud(holding the header) or both?
Any pertinent info would appreciated as well.
2) I'm having trouble matching the vacuum hose diagram to the ports i have on my engine. A '76 2.0. The diagram shows 3 connections at the throttle body.
However, my throttle body only has one connection. I see where one can be eliminated. Is the '76 different? Please advise.
Thanks.
