QUOTE(SirAndy @ Jan 17 2013, 08:50 PM)
QUOTE(Cap'n Krusty @ Jan 17 2013, 05:37 PM)
I'll cut you some slack, what with it being your birthday and all, but the transmission must be shifted manually.
Well, sort of.
Compared to modern auto transmissions, the sportomatic was more of a real manual transmission that had a bunch of gizmos to do the shifting for you.
You still have to move the stick on a sporto, but there is no shift-rod.
It's more of a shift by wire setup.
No, there's a shift rod. It's a manual gearbox coupled to a vacuum servo-controlled clutch... the torque converter is there to lessen shocks to the drivetrain. The shifter is directly coupled to the transmission just like any other manual. A microswitch at the base of the shifter disengages the clutch when touched, engagement
is upon release which is why you keep your hand off the shifter unless you're changing gears. Good practice with a standard manual too. Jim Hall used a similar
setup on the Chaparral, partly to take advantage of the multiplying effect of a torque converter, plus getting power to the ground without tearing up the tires.
Click to view attachmentClick to view attachmentI'm very familiar with these, we own two... and would love to have a 914-6 with the system.
BTW, the old Troutman & Barnes pick-em-up that was beautifully restored as a safety truck by KJ started life as a Sporto!
