Ok, I swapped my late window regulators into my 70 doors this weekend.
Took about 3 hrs total.
You can see the diff in the viewing windows in the door. The late door has a larger area that the regulator bolts too.
Early Door
Late door
I made a cardboard template of the late regulator then traced the bolt pattern onto the early frame.
Drilled out the holes, then enlarged the crank winder hole to 1-1/8 inch.
Next made a template of the area I would need to weld into the early viewing hole.
Cut the bracket out and bent the lower edge on a brake 90deg to stiffen the part.
Next, welded the bracket onto the early door and bolted the regulator in.
You can see the new locations of the bolts needed for the transplant. (blue tape)
To finish the transplant you need
late glass
late vent window frame with fuzzies. Vent glass is all the same.
late fuzzy to put in the rear window slider.
