cwpeden
Mar 24 2013, 12:50 PM
$900 for a set of Boxster wheels.
http://www.usedvictoria.com/classified-ad/...INTERS_19355106These are the wheels i would like to put on my car. Does anyone know what this spacing means? Or is there a website thar explains it....in english.
I'm guessing its the mounting surface offset but which way?
tadink
Mar 24 2013, 01:58 PM
hi -
I just went thru this on mine with some 993 wheels.
I wound up using 2.5" spacers on the rear and 1.5' on the fronts - I could have gone with 3" on the rears I think - they are still a little close to the tub.
Have the guy measure the distance from the inside of the wheel (where it touches the hub) to the inner edge of the tire. You'll need to space it so that you have no more than 5" (so if it measures 7" you'll need a 2" spacer). <<note, I'm working from memory here, and this mind is feeble, your results may vary>>
Then, once you have the things on the car - it will be too high off the ground and you'll be chasing the rear perches and front height adjustment like the rest of us. LOL
td
bulitt
Mar 24 2013, 02:50 PM
Put these on, they sort of look like the old torque thrusts. 7" x17" front with 2" spacers on 911conversion hubs, and 8.5"x17" rears with 30mm spacers. steel flares. 2003 boxster wheels. 215-40 front and 245-40 rear tires.
aircooledtechguy
Mar 24 2013, 08:04 PM
I have a set of those exact wheels that I'm putting onto my shop car. If you should find yourself about 40 miles south of the border near Anacortes and want to test their fit a ser to your car and see how they look before you buy them, please come by my shop.
I really like those wheels. Since they were an optional wheel, they're not too common either. The fronts are 6.5x17 55et and the rears are 8x17 40et. My wheels currently have 235-50 on the rears and 205-50 winter tires installed.
sixnotfour
Mar 24 2013, 08:11 PM
You need 4 fronts and spacers, unless you want to modify your rear fenders...
zambezi
Mar 24 2013, 08:54 PM
QUOTE(sixnotfour @ Mar 24 2013, 08:11 PM)
I would think 8's would fit fine under fiberglass flares, I have 17 x 7's on the rear of my non flared car.
sixnotfour
Mar 24 2013, 08:58 PM
your right my bad..spacers still needed
cwpeden
Mar 26 2013, 10:56 PM
So I'm right? The ET is the offset of the mount surface, but which way?
cwpeden
Mar 26 2013, 10:59 PM
Does this answer the question? Partially.
