I need the O ring for the side shifter assembly. I replaced the shift seal and discovered the PO used a clear sealer for lack of the O ring. In addittion I bought the main shaft seal from Pelican only to find out it appears too small. It looks to be about 1/4" too small and I don't want to remove the old one until I am sure this is correct.
Pelican lists it as "914 all".
