Hey 914 people. I'm new to these forums (just signed up last night). Many here will recognize me from other lists. I've got a question about re-drilled rear hubs.
I've got a pair of re-drilled hubs that I was going to use on my /4 project. Previously, they had been tapped for 14mm lug bolts and used like that. I plan on spot facing the rear of the hubs and pressing in 9/16" x 14mm studs. What's the minimum stud length I should use for this? I will be using 16x7" Fuchs from an SC. I'm not going to get too concerned about having studs wthat are too long as I will just use open faced lug nuts if necessary. I just need to make sure I don't buy something too short.
Thanks
Rick Harris
