I'm replacing my leaking stock brake master cylinder with a 19mm that I had in my last 914. Its only seen about a year's worth of use and has been sitting on a shelf for about as long. I need to replace the fluid reservoir grommets on the top of the cylinder because I believe that when I pulled it out of the car I just yanked them out. Plus its probably a good idea to have new ones anyway.
Question is.. Are the grommets the same for the 17mm master as they are for the 19mm ? That is, if I order them should I ask for 911 grommets or 914 grommets?
Also, whats the verdict on power bleeders? Are they worth it?
-Tony
