Brake Master Sylinder Grommets |
TonyAKAVW |
Nov 22 2004, 04:14 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I'm replacing my leaking stock brake master cylinder with a 19mm that I had in my last 914. Its only seen about a year's worth of use and has been sitting on a shelf for about as long. I need to replace the fluid reservoir grommets on the top of the cylinder because I believe that when I pulled it out of the car I just yanked them out. Plus its probably a good idea to have new ones anyway.
Question is.. Are the grommets the same for the 17mm master as they are for the 19mm ? That is, if I order them should I ask for 911 grommets or 914 grommets? Also, whats the verdict on power bleeders? Are they worth it? -Tony |
TimT |
Nov 22 2004, 04:40 PM
QUOTE Also, whats the verdict on power bleeders? Are they worth it? dunno about the grommets, but the power bleeders are great! I made my own out of of an extra brake resevoir cover, a steel tire valve stem , and a length of hose with a tire valve fitting.. Fill up the resevoir, put the cover on, attach the hose to the front left tire, then bleed away, just keep an eye on the fluid level in the master cylinder. |
bondo |
Nov 22 2004, 09:03 PM
911 hoses are different, but the holes in the MC are the same. 911 grommets won't work, get 914 ones. New grommets make it MUCH easier to install the hoses too.
scotty914 |
Nov 22 2004, 09:07 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
i just reused mine. stuggled for like an hour to get the lines with the grommets on in to the MC. then figured it was much easier to put the grommets in to the MC then install the lines in to the grommets, took about 5 mins
eeyore |
Nov 22 2004, 10:24 PM
Call Tom @ Pelican Parts 888-280-7799. He tracked down the right grommets for me after the 19mm M/C I ordered from them had 2 different sized grommets.
Lo-Fi Version | Time is now: 22nd May 2024 - 04:22 AM |
