OK so don't shoot me down right away but I have spent a good bit of time looking at the various types of bell crank linkage that are out there. To me, the ones with solid push/pull rods are very expensive and have inherent limitations. With the solid rod I would think that you have more areas (push and pull) where the requirement to make adjustments could impact the performance. I have seen some cables systems that eliminate the solid rods, but are still expensive.
I think I have a way to use off the shelf parts to make a cable linkage for just over $50. I was wondering if that had any appeal? It seems that using cables would have an advantage over using rods in that you only had to adjust the pull direction. You reduce the need for adjustment hardware 1/2 and cables are not subject to being bent when performing work on the car and are less likely be a source of adjustment headaches.
Thoughts?
