Thanks, is there a time frame to buff after wetsand?
If there isn't I would buff the entire car after correction.
I give it 24 hours. you might want to wait 48 if your not used to buffing. It is still soft enough to pull easily if you get it too hot. You can buff indefinitely, but the longer you wait, the harder it will be, flip side to that is it will be less likely get it hot enough to pull on you.
