I need to find the grommet that protects the ground wire running to the master cylinder. The sheet metal hole is round and about 1" in diameter. The grommet has a small hole for the single wire and a "neck". I have asked 914Rubber, and he is looking into it. I can't find a part # on any exploded view drawings. The grommet used for the brake lines and fuel lines might work, but it is oval shaped.
Photos below. After I find out if this is available, I suppose I will convert this to a WTB post.
Thanks, Clark
