Full Version: 73 914 with a auto?
fullthrottlerr
Im looking for the eayest way to get a automatic transmission into a 914, I am ok with using a different engine. I have heard of people using a Audi A4 2.8 auto FWD. Is there any outer ideas? I don't need a race car, just something to cruise in. So whats the best options if i have 10k to burn on the engine and trans?
tracks914
Would a VW bus tranny work?
GeorgeRud
Used Boxster? For $10,000, you should be able to get one with automatic, air, etc., and not have any work to do.
rick 918-S
There is a thread someplace here showing a Audi AT bolted to the stock 914 engine. The car was just for sale on Ebay like last week or something.
BTW: welcome.png
TurboWalt
Sounds like a good budget for a Suby swap.
Chris H.
I studied the Subie automatic possibility for quite a while before deciding on a 5 speed. Here's what I learned:
The mid-'90's FWD Subie trans can be used, but the gear ratios are weak. Probably not worth the investment. The 4 speed auto AWD transes (4EAT) are WAY too heavy and you would have to make a custom end plate. The trans that came out of my donor SVX weighs 230 lbs. The gearing isn't so great in those either. You can't use a 5 speed auto because it has a complicated computer-controlled AWD system that would not work with 2WD.
The Passat/Audi FWD auto trans mated to a 2.8L Audi V6 would be a great setup. I learned about the 2.8 from Andyrew's posts on the topic. Only reason I didn't go this way is that it required fabrication of critical parts (engine and trans mounts, etc). With $10k you could pull it off easily.
Andyrew
If you handed a shop 10k you could get a nice condition 2.8 or 1.8T Audi with factory FWD trani installed and all fabbed up.
Problem is at this point to my knowledge it hasnt been done, Closest so far is Mike with his project, but thats a 5 speed.
http://www.914world.com/bbs2/index.php?showtopic=187914
In reality the following needs to be addressed.
1. Mounting of engine/trani
2. Shifting (Easy with auto)
3. Axles
4. Electrical of engine
5. Fluids
Cap'n Krusty
QUOTE(tracks914 @ May 21 2013, 06:42 PM) *
No. Turns the opposite direction, and the design precludes flipping the ring and pinion.
The Cap'n
Cap'n Krusty
QUOTE(Andyrew @ May 22 2013, 08:20 AM) *
3. Axles
5. Fluids
There is a member here with an Audi auto tranny installed in a 914. I believe the PO did the swap. I think it's a pretty easy installation, with the bulk of the funds going to the adapter plate and flywheel. Mounting it should be a couple hours of design and fabrication time, and the shift linkage would be a simple job. If you were to use a Fox or Dasher tranny, the axles would bolt right up. Later versions would likely need different CV joints, which should slip right on to the 914 axles. As the output flanges aren't centered, you might have to source different shafts. Before I retired, I would have taken this on without hesitation. Lack of shop space prevents that now.
Edit: I just looked at the earlier thread. I forgot about the starter location on the Audi trannies. Big hurdle, but it's been done.
The Cap'n
fullthrottlerr
Thanks for all the information, It helped a lot. What is the thoughts on a Subaru engine and trans swap?
d914
I think you would have to look for an older auto.... Front driver.....
Maybe an2.2 with auto.... You might even be able to turbo it.. The older 2.2 were closed decked....
Chris H.
QUOTE(fullthrottlerr @ May 22 2013, 11:56 AM) *
Automatic still or 5 speed?
fullthrottlerr
Im looking at a 2011 Subaru legacy automatic, not turbo i don't want it. Thoughts?
Dave_Darling
I hope you like wiring and electronics hacking! Because almost everything on a 2011 would be computer controlled, and you'd probably have to swap in the whole freakin' dashboard as well as engine and trans.
Early Audi FWD auto trans is the way to go, IMHO. Relatively simple, uses the stock engine, and it's been done so you know that it can be done.
--DD
Chris H.
In my opinion a 2011 Legacy trans would not work in a 914. That is the 5EAT which has a somewhat complicated AWD computer system. It would not work well if converted to 2WD. All AWD Subaru transmissions are extremely heavy and fairly long. The 4EAT for example weighs 230 lbs. You would also need to make a plate to cap off the center diff, converting it to 2WD.
The only Subie trans that seems to be a good fit physically would be a mid-90's legacy front wheel drive automatic trans. It's much smaller. The gear ratios would make the car pretty unexciting. Similar to a Civic or Corolla of the time period. I did a lot of research and really wanted to make it an automatic Subie trans work but in the end it was not worth the effort for me. Don't feel like you can't do it...just an opinion.
Take some time to look at the conversions that have been documented on this site. You'll learn a LOT.
Pat Garvey
O Jesus! Save us!
Why?
fullthrottlerr
Thanks for the input so far, its helping a lot. I will document the whole swap once it starts and show you all.
Thanks Pat.
ok. So i have 10k, I want to change the engine and transmission (automatic), what is the collective toughs on what to use? Ideas help too.
stugray
How about a Toyota MR2?
They were mid engine and had the auto 4-speed option.
You could probably find one in a junkyard for a couple of hundred dollars for both the engine & tranny.
Or there is the Pontiac Fiero - also had a 3-speed auto.
And I have always wondered if a front engine, front wheel drive setup would fit. A Toyota Camry 6 cyl would rock in a 914. Add the TRD supercharger and you would have a serious sleeper.
Stu
d914
2.2 liter turbo suby with an early 2wd auto.. 130-150hp 2200 lbs car with good handling, nice cruiser,, easy in traffic...... Micro squirt, small radiator up front.. most of this has been done.. only the early auto is new.. newer 2.5 liter na engine might fit?? I havent checked yet.. but if engine is an EJ and the auto is from an EJ all should be good..
Chris H.
Pretty much any '90's 2WD Legacy trans will bolt up to an EJ Subie engine. There were compatibility issues with early 90's Impreza 2WD transes (through '93 I think). The newer the better....Subie offered 2WD through 1996, then the whole lineup went AWD only in the US.
Still voting for Audi/Passat Trans with Audi 1.8t or 2.8 myself...
Porsche930dude
how about rigging up a vw AutoStick sort of setup
Andyrew
QUOTE(Chris H. @ May 23 2013, 02:16 PM) *
I agree.
ThePaintedMan
QUOTE(Porsche930dude @ May 23 2013, 10:27 PM) *
All VW transmissions turn the wrong way and all/most cannot be modified to flip the differential.
tracks914
Then go to a good driving school and learn to drive stick........ driving.gif
fullthrottlerr
Thanks guys, you have no idea how much your helping. I wish i could just leave a stick in it, but its for my father who cant push the clutch anymore and the car was his first "new car" in 1973, so the sentimental value is priceless. Im thinking of getting a 1995 outback FWD and just swapping everything over. Im in California so no A/C, just heat, and im going to use renegade hybrids in los veges for the liquid cooling. Thoughts or ideas?
d914
You dont need that much cooling and that $$... AL Celica GTS radiator and fan shroud off of ebay.. a little fab... more than enough.. also other options!!
How much can you do vs. farming this out.. Next find out who your farming it out too!!
Drums66
QUOTE(fullthrottlerr @ May 21 2013, 03:51 PM) *
.....My granny, would be proud!!
Chris H.
Ah well, that explains it better....if it's for your Dad maybe the Subie auto will be OK. That drive train will work pretty well, especially using the whole thing out of the same car. You KNOW it works well together because it's working now. I agree with Greg you really don't need that much cooling....the Renegade setup might be too much since it's designed for a V8 or high HP turbo 4. Do some searches...a Scirocco rad has also been used.
There are a lot of highly skilled people (unlike me) who could very easily do this conversion for you at a fair price. Maybe someone local will PM you who can help.
Andyrew
QUOTE(fullthrottlerr @ May 24 2013, 11:54 AM) *
You've got a lot going on to do everything. Why not call Rennegade and discus the project with them? I am sure they are aware of the market for this type of setup.
Dave_Darling
Early FWD Audi trans, stock 914 motor. Seriously--simple is the way to go.
--DD
Andyrew
^ Just an adapter plate and flex plate, axles, and shift linkage... I agree should be simple.
Computers4kids documented his old setup pretty well I think
http://www.914world.com/bbs2/index.php?sho...mp;hl=automatic
stugray
Have you considered going electric?
Last time I heard, a complete conversion was right about $10K and that was years ago.
The batteries have gotten a lot better lately.
Stu
d914
I read the audi auto thread.... Depending on what Dad wants... but if its the love of that old car... Just do the auto conversion and spend the rest on making sure the engine is in good shape.. Not sure where you live.. Send engine to Mc Mark or some one.. fix and or update to bring to current.. Slap in the auto.. enjoy the car.. Fastest easiest and probably comes closest to what Dad remembers most...
Mike Bellis
Both Audi and Subaru make engine/tranny combos that could be swapped into a 914. Keep in mind these are water cooled, so it's a little more than just putting an engine in.
Most donor vehicles newer than 2000 will have an Immobilizer and chipped key. In the case of the Audi, the immobilizer circuit is controlled by the dash cluster. In my conversion I swapped the cluster, ECU and steering column. Not for the beginner.
If you get an early 90's donor, you can just swap the ECU and TCU (tranny) and be done. Just find a front wheel drive automatic.
fullthrottlerr
So i went with a 1994 Subaru FWD engine and trans, got a good price will everything i would need. new question... what can i use as a snifter? the engine was originally in the front (duh blink.gif ) but now its in the back, so what do i do?
ruby914
QUOTE(fullthrottlerr @ Jun 14 2013, 03:19 PM) *
Can you get the shifter for the donor car? I haven't looked at it but you may need the wire harness for the trans.
This may help, http://ken-gilbert.com/impreza-manuals
http://www.ken-gilbert.com/wrx/mans/1993-1996impreza.pdf
