Back on the subject of D-Jet problem diagnosis...I resurrected this old thread because I had found it while researching what my current problem could be.
Back in late 2013 I bought a rust free and running 914 in TX for $5,600. It sat at my brother's place for almost 2 years while I invested in my "white car" project in SoCal. Last year I had it's (black car inTX) engine rebuilt among other work before having it sent over here to Munich. Just before it was sent, somehow
the AAR valve stopped functioning. I was forewarned that I'd have to replace it. It was idling at about 2500 RPM when it arrived and I bought an AAR (obviously used) and not reconditioned and put it in. It seemed to me to have solved the problem, but my idle was still (usually, but not always) at 1300. I've been driving it for a few months now and have had it out at night only twice or so. Interesting and perhaps a clue here, on those occasions it idled sweetly right around 1000. Any ideas on what this could indicate?
Measuring my gas mileage, I'm only getting 20 MPG, which is minimally 20% more consumption than what it should be.
The idle adjustment screw is all the way in. I have not yet adjusted the screw (counter clockwise) on the ECU but I will do so today. I believe however, that if this works for the idle issue, it is only for the idle (??) and that it won't solve my consumption issue, which could well be due to running too rich, which I've been told by the guy who worked on the car in TX is most likely because the AAR isn't closing all the way. (??). I haven't tested the AFR yet. As far as checking for vacuum leaks, the hoses are apparently all in very good condition and at a glance nothing seems to be poorly connected. But I haven't yet done a smoke test or any other significant assessment of the numerous possible places where extra air could be getting in, of which there is a list in this link I'm adding right here...
This is a great Rennlist contribution on D-Jet:
http://members.rennlist.com/pbanders/djetparts.htmWhen I first start the car it idles at about 900 or so but very quickly (less than 1 minute) goes to 1300-1400, well before the car is even warmed up.
I think I'm going to pull the AAR out and do what this guy on Rennlist suggests: squirt a LOT of WD-40 into it and let it sit, upside down, for a day. Apparently this may restore its full functionality. (??) If that doesn't work, reconditioning the thing seems to be a tough job, so I'll be looking for a reconditioned one and see what happens then. If the problems with idle and consumption persist after that, if I'm not mistaken, the MPS adjustment would be the next culprit...(??). But first things first, right? The AAR is the most likely suspect, right?
I'll stop here. What are your thoughts on these various (??) I've inserted gentlemen? As always, informed input is always hugely appreciated!
Thanks for your advice and feedback!
M.i.M.
