QUOTE(Racer Chris @ Aug 9 2013, 05:31 PM)
QUOTE(billh1963 @ Aug 9 2013, 07:24 PM)
Aren't the stainless lines supposed to be the permanent solution?
They are more durable on the outside which may be good on a race car, but its pretty unusual for a brake hose to sustain damage from the outside on a street car.
On the other hand, the teflon liner is prone to damage from flexing/chafing against the braided stainless exterior and may only last for 2-3 years of regular use.
The rubber lines are going to last more than 25 years in most cases.
Lift that wheel, open the bleeder. If it squirts (no pressure on the pedal) and the wheel then spins freely you need a hose. Make that 4 hoses. If it still sticks, follow that up with a few fresh calipers and a master just for good measure. You don't need no stinkin' stainless braided hoses either. Flush the reservoir and the hard pipes too. Thoroughly.
A wheel bearing would make an unbearable friggin' racket if it was so toasted that it made the wheel hot.
