Fellas,
I've never welded before, but am at the point in the hell hole repair where I can actually start putting metal back in. I have the engine out, all rust cut out (including the old battery tray and support) and need to weld in a new engine shelf and top of the long where hell hole is.
There are two AC lines that come through the sidewall (above battery) that are connected to the compressor. These were fed through grommets in the sidewall and had to have been done prior to "charging" the system.
I carefully placed the compressor on the rear decklid during all of this in the hopes of not having to disconnect these lines (only because I don't know if I can without recharging it).
So.. my question is.. Can I safely weld in new metal in this area without having to remove those two lines? I REALLY don't want to have to hassle with AC stuff after it's all back together. Reason for this is the AC works great and I don't want to mess with a good thing
(you can see the two lines near the top by the negative battery cable post)
(the pic below is just a more recent picture of the hell hole area)
