Hey Steve,
Yeah, I wish I had the financial luxury to do the same. His price is a bit steep for the rod. All in good time. For now, at least I know the part numbers and how it should attach. Not sure what I'm going to do about the tail/side shifter issue on the 915. It's such a straight forward thing from an engineering perspective, but it has to be done right, otherwise the driving enjoyment goes down the tubes since shifting is such a big part of the equation for having fun.
I've done A LOT of reading on the pros and cons of WEVO and Martin's solutions. And both are pricey, relative to my budget anyway.
Although I'm researching the shift rod issue and what to do down the road with the rear/side shifter solution, I am actually more concerned about the 1st and 2nd gear ratios.
I know a lot of guys run out of 1st gear (3.08) quickly with the 901 tranny, but it uses a 7:31 ring and pinion. The 915's 1st gear is a 3.18 with a 8:31 RP. Some guys are talking about just taking off from 2nd gear. This is made all the easier if you have the shorter 2nd gear from a Euro tranny. Anyway, this is all talk for now, as any of the these changes involve great expense in gears and labour for installation.
Thanks again for the insights on the early rod and I'll keep researching. Hopefully in the next year or so, I'll make more progress on my car. Life keeps getting in the way.
Thanks.
Dino
QUOTE(Steve @ Aug 20 2013, 12:28 AM)
The cup part number is the same for the early 914 and the 915 shifter. I don't know about the early 914 shift rod though since i used the PMS shift rod and firewall bearing instead.
