QUOTE(larryp @ Dec 9 2004, 08:53 PM)
So that is the most practical cage for use on the street, with passengers?
A standard diagonal brace in the plane of the main hoop requires that the passenger seat be pushed nearly all the way forward and is uncomfortable for most passengers, to say the least.
This eliminates that problem but is not be as strong in a rollover.
I tried to compensate for the structural deficiency the best I could. The harness crossbar was quite a bit of work and required that I TIG weld 3 pieces together. I'm pretty well satisfied with the design.
One bar I didn't do is a second door bar extending from the main hoop down to about midway on the existing door bar. This would make it more similar to Tony C's standard design, but I'm not convinced it is necessary (and I'm already overbudget).
I already removed the cage and welded up the joints that I could. Joe is taking it home over the weekend to do most of the painting and I will finish the installation next week.
