I had a similiar problem with my 75 side shifter, I bought the shift bushing kit from Pelican, the plastic bushing at the firewall was toast as was the bushing inside the coupler. The bushing at the transmission was the brass one and was in good shape. After I did the repair the car shifted 100% better I was ecstatic with the $43.00 dollar investment.
The plastic bushing that goes in at the firewall, the one closest to the tunnel is easiest put in by dropping it in boiling water for 3 minutes, you can then snap it in place with one hand.
The coupler bushings can be put in by using a bolt and washers and a nut to pull it in place, use the SEARCH option and find the fix, the explanation is excellent and will save you hours. You can get the coupler on and off with a bench vise.
You have an easy fix and if done correctly why would you sell that beautiful car???
Good Luck!
Why am I selling, answer is IN the pic! LOL Bob
Vysoc
