Full Version: Need another nut for the rocker arm
swood
Where on this blasted car can I pick off another nut to replace the one that just got stripped?? I'm not in the mood to go find one as some store. I believe it's a 11mm.
brp914
I believe the clutch cable also uses 7mm nuts (11mm wrench). Borrow 1 from there for today (only today!). But how did you strip that nut? Only needs 10 ft lb torque. Dont retighten before putting the valve cover back on - your valve adjustment will go away.
swood
Aaron Cox
the nuts didnt strip on me....i stripped the studs
swood
That's 100x worse.
Aaron Cox
QUOTE(swood @ Dec 12 2004, 08:02 PM)
That's 100x worse.
not bad..... vice grips and a trip to the bug place....
swood
Got the P&C's back on, valves adjusted, going for the engine tin....hmmm...where is that pesky little CHT that used to be on #3???
