Wow, I'm glad (in a warped sense) that I'm not the only one having "issues" trying to make it out to the track lately!
There were definitely some Mickey Mouse Engineering aspects of my car too. I missed the last 2 or 3 events I optimistically thought I could make. We've finally got most of the initial kinks worked out, and its baseline handling is pretty neutral and stable (now the tuning & further mod process begins).
So I WILL be there Sunday. Can't guarantee that the car will hold together and/or that I'll run any decent times, but I WILL be there...finally!
I need to re-point the car and hopefully squeeze it into V4. Last time I added everything up, I would be in V3 which would not be a good thing the way the car is currently built. (I would only be about 2 or 3" down on tire and 100+ HP short, no problem other than that
) I can always ballast it back into V4 if need be -- unless POC bans adding weight, which I heard was under discussion.
BTW I think I have some extra 911SC A-arms and other bits if your other deal falls thru and/or another crisis pops up. I had a whole front-end but ended up using very little of it (calipers + 1 strut) in my 5-lug conversion.
