Now we're cook'n with gas
QUOTE(timothy_nd28 @ Oct 14 2013, 06:03 PM)
I think he wants a measurement within 0.0001"
That would be nice
QUOTE(r_towle @ Oct 14 2013, 06:05 PM)
0.75 from center to center in either position
Overall 1.50000000
I measured against the edge of the housing to the center of the ball in all three positions
Perfect
QUOTE(Jon B @ Oct 14 2013, 06:07 PM)
Maybe this will help.
There are more precise ways to do this, but I don't have the time.
The lever cannot be in both positions at once, as in your image, and there's no nearby reference to measure against, so I extended the two 8mm studs. The lever ball does not hit the extended stud in either direction, as your image suggests. It comes closer towards the rear, as the stud offset is different. The ball comes within 0.160" (approx) of stud in forward direction, within 0.060" (approx) in rear direction. Inner distance between the two studs is approx 2.280". Studs are not equal distance from the lever pivot point.
I'll let you do the math
Jon B.
Vista, CA
Perfect (again)
Yes, this is for a cable shift idea that I've been thinking about for some time now. Most of the solutions that are used seem to be overly complicated when it comes to the linkage design at the shift console. I have an idea that will have a very simple and robust design with few parts. Now that I have some measurements I can start to draw up things in cad.
Thank you to all
