QUOTE(914itis @ Oct 18 2013, 12:36 PM)
What are the the pros and cons to cutting a hole on the firewall and bolt a remove able plate for easy access? Not just for valve adjustment, replacing alternator belts and even the alternator.
Pro's... a little less hassle...better physical and visual access.
Con's... destroys originalty of the car (not a concern if it's a 6 conversion) and you still have to take out the backpad behind your seats whenever you want access and that takes a little time.
Not sure an access hole helps with Alternator removal/install. You can solve the alternator remove/install issue by customizing your engine shroud so that the tap half can be removed without having to remove the carbs/intakes.
