2073cc Type 4 Hot Rod 'Longblock' Engine
Not a complete longblock, but you get the idea. This is an older performance build that was used in a Sand Buggy in California. It has very cool, very rare EMPI 100mm pistons and cylinders. This was before everything was Chinese I think.
They ALUMINUM FINS on a steel cylinder sleeve. This works great to keep the cylinders cool, but very expensive to make, so they weren't made for long and are hard to find.
Unnumbered case - 66mm crankshaft and supposed to have a good mild mid-range cam. This is a great little engine to build upon, and with a compression mild, could be used in a bus, or in a 411/412 or 914, could be a great hot rod (with some headwork and a bigger cam).
The 1.7L heads look good overall, and the valve sizes are stock at 39.3 and 33mm for intake and exhaust. Stock ports, so would be a great punchy engine.
There are a few very small pieces of fin broken on one cylinder, and the bore of one cylinder looks to have a little wear on the bottom, but nothing that couldn't be run as-is or great with a hone and re-ring.
$500
