I sure thought I saw the answer somewhere here, but I can't seem to run it down now. Will someone please chime in with the degrees of camber per mm of rear alignment shim?
I did see a post that mentioned with NO SHIMS you should get -2 degrees, is that the starting point?
Thanks
