QUOTE(Jeff Hail @ Oct 24 2013, 11:59 PM)
It can be done in the car. Suspension at full droop. Use soapy water or glycerine on the outer bushings. Install one side about an inch into the control arm bushing and then the other side. Keep the middle of the bar down off the crossmember brackets. Wiggle, push, rubber mallet towards the front of the car. It will go in. When the veins in your forehead start coming out .. you are almost there.Then push the bar upward the into the brackets on the crossmember and tighten everything up.
All done.
So, lots of lube.
Push one bar about 2 inches past the end of the bushing.
Keep the sway bar cross bar brackets in the correct orientation....you will see what I mean...
Get a long screw driver and from below lever the sway bar end against the strut...
It will just about make it.
I set everything up, tried a few times, wrote my two threads on here and PP, had some food...went out a forced the damn thing in place.
My arms were tired at the end of it..
rich
