QUOTE(brassball19 @ Oct 30 2013, 09:52 AM)
what our the approximate cost to replace the fuel lines and remove the fuel tank on 1972 914 1.7
Welcome to the world!
I would estimate changing fuel lines in a 914 would be a 2 hour job + parts.
While you are swapping the lines you should upgrade to newer metal lines.
4 piece fuel lines for your car will cost $110 for stainless steel.
You will need rubber FI rated fuel hose (30R9) about 4 feet for $36. You should also change your fuel filter and fuel tank sock. Then you are done.
There is a SS fuel line install video at this link (post #3),,
http://www.914world.com/bbs2/index.php?showtopic=110158Where in So Cal are you? I am in Los Angeles.
-Robert
