QUOTE(Mblizzard @ Nov 4 2013, 06:33 AM)
But when I have both carbs balanced at idle, at 1500 rpm on is at 7 the other is at 10. So I work on the linkage of the one lagging for a while and get it to 7 at 1500. Secure everything. Runs great sitting. Go for a drive and it gets out of balance above idle. Spent 3 hours doing this dance and never could may it work. Granted it may be operator error but I think there is something wrong with the linkage.
If the adjustment is changing just because you're driving it then something's not staying where you put it. So if something's moving, what is it? And why? First do you still have some cable slack at full throttle? By that I mean when you floor the pedal are you pulling at the linkage past its stop? On either carb? If you are and you floor it on your test drive you're stretching and "unadjusting" the linkage. Second if something's moving you should be able to find it. Take the linkage drop arms and twist them (softly!) back and forth in different directions. Feel anything moving? Do the same (softly!) with the cable arm and each drop arm, back and forth, anything move? And is the length of your hexbar adjustable? How do the ends sit in the carb mounts? Can you feel any binding? Some have bushings, some bearings, push the bar back and forth and in and out near the carb pivots, feel any movement?
By the way, before the protests start I'm NOT endorsing hex bar linkage, by any means. It has two problems, first the initial setup and second maintaining the setup. The initial setup is logical, you just need to go through it and there are DOZENS of instruction sets on the web, just google. The second, staying in adjustment, is problematic because hex bars have so many different components that are long levers with angles joined with fasteners, so even slight movement anywhere will put them out. That means their adjustment doesn't last as long as it should, but that's typically months or more between adjustments, not minutes. You can do this, tens of thousands of other have, just work your way through it.
EDIT: One other thing, is your hex bar steel or aluminum? If it's aluminum then you can still adjust it, but start saving for something better. And it is a real hex bar, right, not tubular? There were some really cheap tubular bar linkages sold, but I doubt there are any left that haven't been thrown into a lake by now.
