914itis
Nov 7 2013, 02:44 PM
I am looking for the air filter housing fore the 914-6, with the holding bracket.
Let me know what you have.
Thanks,
andrew15
Nov 7 2013, 03:53 PM
Are these the same as early 911 air filter housings? I may have one from a 1970 911T
914itis
Nov 7 2013, 04:22 PM
I was told that I can make not fit.
Pm sent
sixaddict
Nov 9 2013, 07:17 PM
Believe I have one
It's plastic where as 911 is metal (correct?)
It has had snoot cut
If interested pm email address I will send pics
Thanks
racerbvd
Nov 9 2013, 09:18 PM
914itis
Nov 9 2013, 09:28 PM
Is this pointing to the right side?
I think the snorkel should point to the passenger side facing the front of the car.
experts ?
earossi
Nov 10 2013, 01:45 AM
QUOTE(914itis @ Nov 9 2013, 07:28 PM)
experts ?
I believe the pictures are correct, which shows the inlet to the filter pointing to the passenger side of the car.
billh1963
Nov 10 2013, 07:03 AM
Inlet is pointing the wrong way....
Looks like it could be flipped around?
earossi
Nov 10 2013, 08:07 AM
QUOTE(billh1963 @ Nov 10 2013, 05:03 AM)
Without seeming argumentative, I had this exact air cleaner on my 1966 911 that was fitted with Solex carbs. There is a vacuum fitting on the back side of the air cleaner (opposite side from where the snorkel is located. That vacuum fitting faces the front of the car. So, all the views given in this ad can be a little bit confusing.
So, to be perfectly clear....if you were to stand at the rear of the car and opened the engine lid to look at the engine, the snorkel should be pointing to the right which is the passengers side of the car. The "Y" shaped tee located at the inlet to the snorkel should be pointing "down".
914itis
Nov 10 2013, 09:26 AM
I am confused. Ahold the snorkel gave the rear trunk or the back window?
If it should face the back window then the one on the picture, when installed, if flipped around the T will face up.
914itis
Nov 10 2013, 10:01 AM
According to a few threads here, it should look like this
If someone can confirm it can be flipped then it's good
andrew15
Nov 10 2013, 10:16 AM
QUOTE(914itis @ Nov 10 2013, 09:01 AM)
I'll dig mine out today, to check
The 914/6 one should be metal - the plastic ones were for the 72-73 911 MFI systems.
AM
toolguy
Nov 10 2013, 11:17 AM
"The 914/6 one should be metal - the plastic ones were for the 72-73 911 MFI systems."
I've had a few 914-6's. . . all were plastic. .
racerbvd
Nov 10 2013, 12:02 PM
QUOTE(scotty boy @ Nov 10 2013, 08:37 AM)
Paul I'm sure Byron is open to a trade for the filter
Same here..
I'll pull out ,my NOS one (NOT for Sale or trade, for the 70 concours build)
I just happened to have this one handy and figured I would offer it up..
Mark Henry
Nov 10 2013, 12:15 PM
Just to be clear you need the 2 parts that mount on the carbs as well, as seen on the left in this pic.
andrew15
Nov 10 2013, 12:18 PM
QUOTE(racerbvd @ Nov 10 2013, 11:02 AM)
Same here..
Odd - I was sure they were metal, oh well, you learn something every day!
914itis
Nov 10 2013, 12:21 PM
QUOTE(Mark Henry @ Nov 10 2013, 01:15 PM)
I am aware, thanks Mark.
earossi
Nov 10 2013, 12:42 PM
That air filter housing should work fine in a 914. The snorkel sits just above the engine cooling fan. Since in a 911 the cooling fan faces the rear of the engine bay, the snorkel faces to the right as viewed from behind the car looking forward.
Since the 911 engine cooling fan faces the firewall when installed in a 914 (i.e the motor is rotated 180 degrees), the snorkel is now facing to the left ( towards the oil tank). It should work fine; or you can always shorten the snorkel with a hack saw.
smg914
Nov 10 2013, 08:46 PM
asdf
