QUOTE(76-914 @ Nov 20 2013, 11:04 AM)
acc position?
don't think we have those. you should have presence of voltage the first 1.5 seconds after the key is turned to the "on" position. After that it goes off until the engine starts.
Sorry, just got the car recently. "On" position then. I'm guessing I shouldn't have continuity with ground on both terminals though, right?
QUOTE(type47 @ Nov 20 2013, 11:08 AM)
QUOTE(76-914 @ Nov 20 2013, 08:04 AM)
.... you should have presence of voltage the first 1.5 seconds after the key is turned to the "on" position. After that it goes off until the engine starts.
Unless he has L-Jet or maybe carbs. If the OP of this wants time efficient answers to their questions, they need to supply a lot more info, ie, MY, type of fuel system (D-Jet, L-Jet, carbs, other...)
best if the info is put in their signature
location info could bring out some local 914'ers who could help
I've got D-jet. I'm pretty new to 914's so I'm still figuring a lot of this stuff out. Location info is over on the left under my name.
Basically the car has stopped running and I'm trying to figure out why. Engine cranks but doesn't fire up. Just trying to rule out the possibilities.
