QUOTE(messix @ Nov 25 2013, 03:39 PM)
QUOTE(Andyrew @ Nov 25 2013, 09:59 AM)
Turbo lag can be reduced by the following.
Ceramic ball bearing turbo's
Billet aluminum wheels and better metal technology
Better fin design technology
Twin scroll exhausts (two cylinders that fire at the same time feeding the same exhaust side giving more push per combustion)
Appropriate sized intercoolers, intake and exhaust piping.
More aggressive timing, and better gas
A combination of all that, with a smaller turbo that can be run at a higher boost more efficiently, IE if one turbo is efficient to 20psi but a smaller turbo is efficient to 35psi and therefore can make more power up there, you will have a gain in power and boost response.
Then there are antilag systems, but this is not something for a street car.
Variable vane turbos also
I dont trust those... Seems like a failing technology.. Only one production vehicle uses it (Granted its a 911 turbo). Personally I would rather have a nice twin scroll billet ceramic ball bearing turbo with an extremely efficient fin design than an overly complicated variable vane turbo.
BUT yes, I should have added them to the list... I thought about it, but didnt..
