The project is moving now that the floors and back inside and outer firewall are replaced. I am primarily posting to show how cheap I am.
We sawed the hatch and welded about a dozen 8 mm nuts around the engine bay edge, bought a nice slice from the car that gave it's life so that a Ghia can tear up the highway - thanks. The green primer was temporary, cleaned it up and covered the whole inside with DP-50 epoxy.
I got a Caswell plating kit. Zinc followed by a cad-like bath. These were completely covered with rust. Phosphoric acid followed by the plating.
So now the cheap. I wanted a fancy bushing for the shift rod. When the linkage is solid the shifts actually are pretty good with a 901 box.
So I bought an $8 pillow block.
Of course it was 3/4 inch so I had to pull out the ball bearing and put it on the lathe to open it up. Since I had the lathe going I also put the casting on and took about half of the iron off as well. Lighter, eh?
Here it is in the car -
And of course when the lower firewall rusts out there is collateral damage. In my case I bought some stainless tubing for the e-brake tubes. Need that pricey orange covered silver braze, but it was fun
So I am trying. Too cold and salty to drive the 2056.
