bigkensteele
Dec 30 2013, 09:53 PM
I understand that the piston diameter is larger on the six caliper, but externally, they appear to be very similar if not identical.
My question is why can't a rear four caliper be bored to the same piston diameter as the six? Not enough meat on the bone?
Mind you, I understand that if it could be done, PMB probably would not have gone through the trouble to create the GT caliper. Just being curious here.
Steve
Dec 30 2013, 10:22 PM
It's not just the piston, the pads are also slightly bigger.
mr914
Dec 31 2013, 06:05 PM
There is also a difference in the casting
The 4s have a couple of extra ribs
Eric_Shea
Dec 31 2013, 06:15 PM
Piston - You would need 2.5mm off the edge of the dust boot flange. There's just not enough meat there to make that happen.
Pad Width - Not only the cavity but the pin spacing would need to be expanded.
All sorts of issues...
