Allan
Dec 31 2004, 10:26 PM
Finall got around to start putting my motor back together. Only have 1 picture I can post but there will be more as things progress. So far I have the crank back together.
DJsRepS
Jan 1 2005, 05:34 AM
I dont see a torque wrench in the pic. You set your rods with that vice grip. Just kidding. What cam are you using? Carb or FI? 2.0L ?
jwalters
Jan 1 2005, 06:23 AM
Where is your rear main seal and "O" ring at????
Allan
Jan 1 2005, 09:11 AM
Not to worry, vise-grips are calibrated
Everything torqued down properly. Actually, after getting this far, my son stopped by and we reassembled the cases.
I will post some pics of that a little later.
It's going to be a stock 2.0 w/D-jet and a slightly modified Elgin cam and euro pistons. Gonna continue on today and hopefully get the P/C's and heads on.
DJsRepS
Jan 1 2005, 05:42 PM
Sounds great GOGO Djet. I like the Djet
Allan
Jan 1 2005, 08:08 PM
Okay, so far I have the cases back together, the distributor indexed and in (Had to rotate the clamp about 45 degrees though
) hopefully correct. Motor is up on the stand. Got the oil pressure relief in and the oil pump (Except for the front plate due to a torn gasket
) installed. Didn't get the heads lapped today so hopefully tomorrow I will have time for that and to install them. And my camera has problems
Allan
Jan 2 2005, 02:34 PM
Finally got the camera to work. So here is where I am so far.
Allan
Another.
Allan
Jan 2 2005, 02:36 PM
Now which way do these Euro pistons go in? They have no arrow. And what's up that they do not come with the retainer cir-clips?
Allan
Mar 14 2005, 05:12 PM
Just an update on what it looks like so far.
Allan
Mar 14 2005, 05:13 PM
I know, last one was just like my avatar.
Allan
Mar 14 2005, 05:14 PM
Another
Allan
Mar 14 2005, 05:15 PM
More
Allan
Last
TravisNeff
Mar 14 2005, 06:33 PM
looks good kemosabe.. I did the same aluminum paint on my fan shroud too, looks good!
jd74914
Mar 14 2005, 07:53 PM
What kind of paint did you use on the tin and fan shroud and what colors. I really like it
, and my engine is getting pulled for a rebuild soon?
Allan
Mar 14 2005, 09:16 PM
I used an industrial enamel on the tin that we have at my office. I'll try to find out who makes it. All I know is the can says RED.
The fan housing was painted with regular rustoleum aluminum paint.
newdeal2
Mar 14 2005, 09:31 PM
Rusto is actually pretty good. My tins and fan housing are holding up fine so far.
BTW...those don't look like euro pistons...I see a dish. Mine are dead flat.
Allan
Mar 14 2005, 09:39 PM
Actually that's a raised area. Seems to fit okay.
