Danke,
We found them while dealing with caliper compensating line issues. We ditched our previous supplier because they were;
1. Slow
2. Expensive and
3. They didn't fit. We would spend an hour just to get S-Caliper lines to look right.
We went to SEMA and found a new supplier. Sent them some S-Caliper lines that were perfect. They had the new technology. 3D scanner and CNC tubing bender. The lines they sent back were amazing. That gave us the confidence to approach them for complete kits, all pre-bent etc.
Rich Dauenhauer to the rescue. Rich had all of the lines cataloged for all of the years. Rich sent us the lines which we had scanned and done up.
The only problem for 914 guys is this: the most expensive tubing is correct for our cars. The green coated tubing from Europe. Strangely enough, the 356's and the 911's didn't have this tubing. I'm guessing it's probably a VW werks spec item. So, seeing as how it's imported and only used in a limited number of vehicles, it becomes the most expensive.
Tin coated steel that Matt mentions is the standard on all 356's and 911's. That's the least expensive tubing. Stainless is about $10.00 per line more (average... with an average of 9 lines in a 914).
Krusty is really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, old. I don't think stainless was invented when he was working on carriages.
We sell them individually or in sets. We don't have the sets loaded on the site yet but, you'll find them in the Member Vendor section. Check out Andy's build if you'd like to see a full set of the factory green lines.
http://www.914world.com/bbs2/index.php?sho...1062&st=790
