Full Version: Best Distributor for Dual 44 IDF 2056 Engine
'70PVW914
Hey folks.....Been poking around my 914 and will be replacing various parts over the weeks here.
For the distributor, which on mine is an old, pointless Allison model, I wanted to replace it with a Bosch and put in pertronics...then I found this "SVDA" thing on ebay...just wondering if its a good value, as it seems to be a brand new bosch, with the pertronics already installed. Good?
http://www.ebay.com/itm/321275352048?ssPag...984.m1423.l2648
McMark
I use the mechanical advance Mallory (4554101).
Jonathan Livesay
Bosch 050 is very good with or without Pertronics I don't think that a 009 has enough advance for the Porsche version of the type4. There are probably some other newer ones that are made with more advance than the 009 but I don't know which ones are best.
finchmunoz
Try CB performance black box:
http://www.cbperformance.com/ProductDetail...roductCode=2013
You may use any dizzy but it'll give you the qualities of a mechanical advance at the top end and svga advance at the low end. . .
So at idle, you can set your timing to 0 deg. Cooler engine in traffic.
