Ok, I picked up that transmission.
$600, It was missing the for the clutch release lever shaft. I will try to make one tonight. Last night I made the back cover.
Here is a photo of the new 1/4" cover. Only took about 1 hour to make. Traced, dupe punched, cut with a band saw, drilled and cleaned up the band saw cut with a hand router with a rotary file bit then found a 45 degree bit to chamfer all edges. Climb mill cut everything with the hand router gave it the milled look.
I am thinking about masking it off and spraying it with latex paint and try a little chem-mill etch.
One
thing of the things I found that I don't understand is this cap on the out put shaft? If this was AWD why have this capping the shaft?
As far as the locking adapter, I an not completely clear how to make or install it.
This differential is different than I saw in (I think it was JPNovac's) thread, on how to convert. It looks like Bremar took down there online install directions, If they ever had them online. I am also looking at a blank PDF from dunebuggyarchives.com
I find Factory Five has a lot of good information but not finding what I need. Still digging...
