Hi All,
This is a follow-up to my rant on the JCS "QUALITY" Air Cooled Engine I bought about 8 months ago. Yes, I know NOW what I didn't know then - & YES JAKE - I effed up.
I'm way behind my money / time curve & at this point I could easily justify a Raby 2270...
My rant today is based on the JCS long-block I bought.
First, I noticed that the heads weren't vented. Fine. Whatever. I vented the heads.
Second, when I pulled the v/c's to prepare for adding the vents I couldn't help but notice that the builder had used nylock self locking nuts to attach the rocker shafts. AND, two of the studs that the "nylock self locking nuts" attached to had insufficient thread protrusion.
In other words, the nylock portion of the nut was ABOVE the stud. So I went to my local flaps & bought slim-line grade 8.8 M7-1.00 nuts. Today I R&R'ed the nuts - one at a time. Loosened each rocker's nut about a 1/2 turn to relieve tension first. All went well until I got to one nut that when I removed it - the stud started coming out with the nut. I stopped & attempted to re-tighten the nut to see if the stud would screw back in. It did.
I installed the new nut. When I attempted to re-torque the nut, the stud turned in the head & I couldn't pull 120 in. lbs. (10f.p.) - My first re-torque point...
So the effing head is stripped - or the stud. on my NEW JCS "QUALITY" rebuild
And, BTW - This engine has not been run by me. But, JCS documentation indicates that it was run & evaluated for "quality" prior to shipment.
My question:
Any reason why I can't install a heli-coil & THEN get this POS in my car???
I'm so pissed at the crappy workmanship I've seen so far, all I want to do is install the BIOTCH & run the 'effing $hit out of it while my piggy$$$bank saves up for the Raby engine I should have bought -
