jim_hoyland
Jan 30 2014, 07:10 PM
We are going to remove the tranny while the car is on a hoist, up 6' in the air. The plan is to support the engine with a 6' ladder. The rating of the ladders is close to the weight of the enngine.
I'm going to cut a 2 x 6 or 4 x4 to support the engine; the board will be bolted to the top of the ladder.
Question is :how wide should that board be ?
r_towle
Jan 30 2014, 07:20 PM
Hahaha
It will only touch one small point, so cover the top of the ladder.
Sounds like a crazy way to do it, maybe look at a way to hold the motor up from above by running a 4*4 across the engine bay and bolt a chain to the upper case bolt at the rear, sling that chain around the wood beam....done.
jim_hoyland
Jan 30 2014, 07:23 PM
QUOTE(r_towle @ Jan 30 2014, 05:20 PM)
Hahaha
Good suggestion !
r_towle
Jan 30 2014, 07:25 PM
You can hold the engine with one hand if the engine bar is in place....
Just put towels under the wood beam.
jimkelly
Jan 30 2014, 07:41 PM
remove starter before you lift car.
