QUOTE(Philip W. @ Feb 12 2014, 06:41 AM)
recently when i pulled my head exchangers for doing the clutch etc, several exhaust studs pulled out due to the nuts rusting to the studs, So i ordered new ones. I just wanted to make sure when i put the new ones in can i prevent this from happening in the future by using locktite, or is this not advised due to head at this location? if so which kind? AND should anything be applied to the threads before the new copper nuts are put on when the H.E.s are put back in place.
Thanks.
Your turn for the lecture. Shoulda kept a copy of the last one so I don't have to keep repeating myself. First, the factory did NOT use ANY type of self locking nut on ANY air cooled application. They used two kinds of exhaust nuts, one for the 1.7/1.8 cars, a Helicoiled regular looking nut, and another for the 2.0 cars, with a thick flange as part of the nut, and also containing a Helicoil (see the picture below). Second. Those "copper nuts" aren't copper, they're copper plated steel. They were first used on the VW Rabbit in 1974 and spread, like an unstoppable infection, to the aftermarket aircooled scene.
You don't want a locking nut because it increases the chances of breaking or pulling the stud. Pulled studs can affect the threads in the head, and then you have a REAL problem.
Click to view attachment Have fun, and THINK about what you're about to do. BTW, I think I still have a little over 1 set of those nuts in the picture, and they're for sale.
The Cap'n
