boxsterfan
Mar 24 2014, 09:28 AM
So my clutch cable on 74 2.0L is starting to fray at the pulley. The fraying is occurring where the cable exits the "top side" of the pulley as it goes towards the adjusting nut. Pretty much right at the pulley.
Is this the common area for these cables to break? Or is it out of adjustment in some way that caused this excessive wear?
I can order a new cable from Pelican Parts for $16.50, but is there an alternative (better?) cable to order that is more durable? Any other items I would need to order with this (pulley parts, lock nuts, etc...)?
And how hard of a job is this replacement?
JawjaPorsche
Mar 24 2014, 10:03 AM
Not a hard job. I have heard pros and cons on more expensive clutch cables. Haynes manual is great for this job.
They like to break at the pulley. Replace now before you get stranded. Plus you will lose valuable hardware at the end of the cable.
I carry a spare in my trunk!
http://www.shoptalkforums.com/viewtopic.php?t=34340
AfricanHijinx
Mar 24 2014, 10:07 AM
its pretty easy to do the I got one from FLAPS and its seems to be ok so far
Jeffs9146
Mar 24 2014, 11:44 AM
Just be sure not to wrap around the accelorator cable! Otherwise very easy!
stugray
Mar 24 2014, 12:37 PM
Sort of on topic: Where can we get replacement clutch pulleys?
PP says NLA.
I would prefer one made from Aluminum. Who makes them?
JawjaPorsche
Mar 24 2014, 01:50 PM
QUOTE(stugray @ Mar 24 2014, 02:37 PM)
PP says NLA.
Auto Atlanta
http://www.autoatlanta.com/Porsche-Clutch-...442325502D.html914 Rubber
http://shop.914rubber.com/914-Clutch-pulle...m?categoryId=-1
KELTY360
Mar 24 2014, 01:52 PM
914Rubber.com
malcolm2
Mar 24 2014, 02:07 PM
QUOTE(boxsterfan @ Mar 24 2014, 10:28 AM)
Buy 2 and keep one in the car to install on the road one day.
toolguy
Mar 24 2014, 03:14 PM
You want a plastic {Nylon / Delron} pulley, not metal. . metal ones will cause the cable to fray sooner. . far easier to change a pulley than a cable. .
stugray
Mar 24 2014, 05:16 PM
Thanks all!
I looked at 914 rubber first but didnt find it first time thru
Order placed!
1970 Neun vierzehn
Mar 24 2014, 08:24 PM
Boxsterfan,
I replaced my clutch cable for the last time back in 1979. Up until that time I kept the nylon pulley and cable clean and dry. It frayed and then separated. Back then, I ordered two clutch cables from Stoddard in Cleveland, so I would have one as a spare. I still have the second one as a "spare", and the replacement from 1979 is still on the car, and in fine shape. The solution to eliminate the fraying/separation of the clutch cable around the pulley assembly is to keep that area very well lubricated . I routinely inspect the cable and pulley and keep it slathered in white grease. As soon as the grease gets dirty and marginal looking, I wipe off the old lubricant and smear clean grease onto the cable & pulley. I'd say 30+ years on that cable validates my maintenance regime.
Paul
partwerks
Mar 24 2014, 10:06 PM
I made a bracket with a series of holes that I could keep moving it outward until I got to where I could get all the slack out of the cable. I have the pulley laying horizontal. I used a pulley off of a garage door spring, with a roller bearing in it. Just had to trim off about an 1/8" off the diameter for it to fit down into the saddle. Used square tubing to space it to where it goes towards the fork at an acceptable angle, and mounted the bracket to the same spot as the original. It pushes much easier.
Click to view attachmentClick to view attachment Click to view attachmentClick to view attachment
abes914
Mar 24 2014, 11:02 PM
i just replaced mine a month ago. fairly easy and i am not an expert wrencher. i ordered the terry cable from pelican parts. it seems more heavy duty compared to reg clutch cable.
boxsterfan
Mar 25 2014, 09:31 AM
Thanks for all the tips here on this thread. I ordered a couple "regular" clutch cables from PP to arrive this week. My car already has a delron pulley from the PO. I'll take the advice of keeping it greased up as well.
boxsterfan
Apr 5 2014, 07:39 PM
Changed out my clutch cable today. Not a bad/hard project, but having to take out the center console a bit annoying.
Glad I changed it though as this is what I was shifting gears with:
boxsterfan
Apr 8 2014, 10:07 AM
Quick question about clutch cable adjustment:
Now that I have my new clutch cable in, shifting is definitely better. At what point should the clutch be engaging when pushing in the peddle? Closer to the top?
Mine engages/disengages pretty close to the top. I have also heard that the cable may stretch some after a bit of use.
JawjaPorsche
Apr 8 2014, 10:54 AM
QUOTE(boxsterfan @ Apr 8 2014, 12:07 PM)
It will stretch so adjustment maybe needed in a week or so.
Jeffs9146
Apr 8 2014, 10:57 AM
I had to adjust mine 3 times over a month of driving before it settled down!
jaxdream
Apr 8 2014, 11:21 AM
What are some of the advantages of a horizontal pulley setup ??? Does the cable really know what the orintation is ??? Not trying to be a wise acre...as I have seen a few run the horizontal , Racer Chris maybe .
Jack
ClayPerrine
Apr 8 2014, 11:30 AM
Funny... my 914 doesn't have a pulley. The clutch cable comes right out of the firewall and connects to the throwout arm.
I used a 71 911 trans case and the 225mm pull type clutch. That gives a stronger clutch, no clutch cable pulley, and no pressure on the clutch cable tube in the body.
Next stop for me is a hydraulic clutch.
Dave_Darling
Apr 8 2014, 11:56 AM
QUOTE(jaxdream @ Apr 8 2014, 10:21 AM)
Gets it out of the way of some header designs. That's the main thing I know of.
Makes a nice shelf for dirt to accumulate on, too...
--DD
boxsterfan
Apr 17 2014, 09:11 AM
So last weekend, I adjusted my new clutch cable after 1 week of driving. I ended up tightening the nut in a couple full turns. Now this week, it feels like it needs adjusted some more already.
I assume I should just be adjusting the nut a couple more full turns in each time until it stops stretching? Also, I believe I should be feeling clutch engagement/disengagement fairly highly on the clutch pedal?
The shifting is good, but getting into first gear at stop stop is hit/miss. Sometimes super smooth and sometimes alot of jiggling to get it into gear. Also, second gear seems a little rough to get into at times. I'm guess I should have a look at my firewall bushing this weekend also.
Dave_Darling
Apr 17 2014, 04:23 PM
Pull off the carpet over the center tunnel. Look through the hole in the gear shift lever base as you push the clutch pedal. If you see the cable moving left-to-right, the clutch tube has broken loose and you need to fix it.
--DD
orthobiz
Apr 17 2014, 04:51 PM
Clutch engages fairly high, not on the floor.
Paul
boxsterfan
Apr 18 2014, 09:54 AM
QUOTE(Dave_Darling @ Apr 17 2014, 03:23 PM)
--DD
Thanks, I'll have a look this weekend since my center console is still out of the car.
boxsterfan
Apr 18 2014, 09:56 AM
QUOTE(orthobiz @ Apr 17 2014, 03:51 PM)
Paul
I feel mine is that way.....seems like for shifting I have to get the pedal almost all the way to the floor, but I feel it engage into the next gear (ie going from 1st to 2nd) pretty high on the pedal.
TIA...
