Full Version: Improved shifting for side shifters, bolt on? Maybe.
Pages: 1, 2
Dr Evil
I have had this though for a long time to try and remove as much slop as I can in the shifting system. The tail shifter is a bit trickier, but not impossible. I have a side shifter in my new 914 and so, while I build up a transmission for it to drive to Hershey this weekend (this will be the raffle transmission, BTW. Trial by fire!), I decided to see how simple it would be to remove some of the slop.
First, see how much of a gap there is between the shift selector comb and the rod. Click to view attachment
This is a huge amount so any bit that can be removed should be an improvement.
Step one was to add material to the sides of the comb faces (Yes, Scotty, I welded). Then, I hand filed the faces and re-formed them to a specific profile. The metal that was added was hardened and a real bitch to file. I figured it was worth it.
The end result was a much tighter fit.
There are a few parameters that I will not go into that need to be respected to get this to work, but the preliminary results were nice on the bench. With the material added and profiled on the faces, the stick throw fore and aft to select gears decreases significantly. There is still refinement that needs to be done on the profile, but so far the preliminary results are encouraging.
Next, I will build a jig so I can directly observe and adjust my profile. And I will also be able to see where I can add material to take up the slack that one feels when they are in gear and can wiggle the stick back and forth.
Once I get this prototype done and tested, I can do this treatment to any side shift console on an exchange basis and it will be a quick bolt on improvement (I hope).
boxsterfan
'73-914kid
What kind of clearance are you aiming for between the comb and the shift fork selector? .08-.1"? Seems like too tight might be a problem, but I love this solution... The never ending process of making these cars shift better should interest a lot of people.. beer.gif
HalfMoon
bulitt
Seems the play may be "designed in" to compensate for movement of the engine and trans under braking and acceleration ? But finding out how much is too much is trial and error (which I assume is what you are trying to determine). Could be dependent on the condition of your motor and trans mounts also.
Dr Evil
QUOTE('73-914kid @ Apr 15 2014, 02:05 AM) *
"Seems like too tight.." This is why I actually built and tried it. As mentioned, it works. Clearance will be my secret. wink.gif
No armchair engineering here. Do or do not, no guessing.
IanS
So you say this can be similarly engineered for tail shift? Do you have access to a tail shifter to test/engineer?
CptTripps
QUOTE(IanS @ Apr 15 2014, 11:34 AM) *
If there's one thing I'm certain of...it's Dr. Evil's rolodex of people with tail-shift transmissions.
mskala
For the -6 version of the tail shift, I did basically the same thing last year:
914-6 shifter slop improvement
It didn't hurt, but I didn't notice any real improvement either.
Dr Evil
For a tail shifter you would need the external shift rod, too. You have to add material to the ball. Then, you have to take the whole stack out to get to the internal shift actuator and add material to that. The real problem with the ball on the inside actuator is you have to put some material in a specific place on it (hard to describe) so that you do not get it wiggling side to side when it is in gear. To make a tail work as well as I can make a side.....it would be a task. I am interested in doing it, but do not have a car with this set up. Also, side is sooooo much easier.
Dr Evil
QUOTE(mskala @ Apr 15 2014, 12:43 PM) *
Mark, without addressing the internal shift mechanism you will see limited results. The problem with the tail shifter is majorly within the box. If you saw how these things actuate internally, you would be shocked. It is so loose as to be a joke. So much room for improvement. I would love to do a mod on a /6 if anyone is interested. I would throw it in with a rebuild. The stuff that needs to be done to a tail shifter would best be done with the whole box here. If I have the box to play with, I can adjust to the box and its rods. Otherwise, I have to leave a little slop so it will fit all boxes.
GeorgeRud
I always looked at that coupling and figured there was room for improvement in the design. Tightening the clearances should help, but I assume there must be some 'wiggle room' to allow the slight angulation as you shift through the gears.
Would a system composed of rod ends allow for the necessary movement and cut down on slop, or is there more clearance inside the gearbox that would negate any improvements to the external components?
Dr Evil
My side shift kit would just be the shifter comb. All other factors are being evaluated and controlled for. The fore and aft have been tested. Tight tolerance used and effective. Now I need to see about removing the side to side shift rod play in the cabin by adding beef to the thickness of the comb teeth rather than just the width of them. I need a jig for this and hope to make one tomorrow if I can find my sawsall happy11.gif
Harpo
David
Dr Evil
veekry9
Dr Evil:
Delicate work,reducing the tolerance and clearances within the shifter forks.
Question:Are you using a jig to determine the distance to the ball detent?
I am about to embark on a re+re of the original tailshift TX that is now on the floor of the shop.Here it is 4 decades hence and I am considering a hydraulic shift mechanism
for the unloved early box.I have seen a number of attempts to resolve the "loose'
shift characteristics with limited success.There's gotta be a better way.
Krieger
Cool!
'73-914kid
Keep on pushing through with this Mike. BTW, if you need someone to do some testing per say with this, I'd be more than happy to.. Being a daily driver, my car undergoes more wear and tear than most, so it might be a good candidate for testing this out.
In all seriousness, I'm not trying to get a free part, but for longevity testing on the tightened clearances, it could be the perfect platform.
Woody
914_teener
Doc.
My box will be in transit in a week. I am cleaning it.
I would love a tighter shifting box.
All inuendos intended and true.
Dr Evil
I'll at least be testing the one iteration of this to, at, and from Hershey this weekend. I will let others check it out, too. I hope to get both parameters that I am shooting for resolved to my satisfaction. It all depends on tonight and Thurs. The transmission is pretty much done other than the case seals and assembly. Once the shifter comb upgrade has been tested in the testing jig I will be building, and shown to work, I t goes in the box and the box in the car.
I am serious about doing a tail shifter one, just for the hell of it. I just need a candidate. Anyone need a rebuild? I can also do a 911/912 box.....I think I will use my local friend for that. A 911/912 box would be markedly easier than a 914 tail box. Only one shitty connection to worry about rather than 3.
stugray
I have a tail shift laying in pieces from my last rebuild.
I wont be needing any of the tail shift pieces ever again.
I would donate to the tailshift cause if it also helps with the side shift development.
Let me know if you need some parts.
Stu
Dr Evil
Dr Evil
QUOTE(stugray @ Apr 15 2014, 07:50 PM) *
Stu
Thanks, Stu. I am balls deep in tail shifter parts, I need a whole box that will be built, modified, and then extensively tested by the owner.
QUOTE(Dr Evil @ Apr 15 2014, 08:09 PM) *
Stu
Mike - let's talk at Hershey. I'm driving my '71. All stock and keeping it that way but I wouldn't mind a tighter shifter
Dr Evil
yeahmag
Killer!
Dr Evil
Success!
Tonight was very good. I made a jig for evaluating the comb in action. Did so, and got a lot of good data that I used to direct where to add material. I added material, honed the profiles, and saw a marked 90% reduction in the movement that will be translated into lateral movement in the cabin stick shift.
The profile for the fore and aft aspect still needs refinement, but with a transmission to finish, and with being freaking close to perfect for what I was trying for, I opted that an 85% reduction in fore and aft cabin stick slop would have to do smile.gif
The test tranny is almost done. About 1hr left and then I need to jack up the car and swap them out. I wish I could have gotten a short shift kit in time, but Pelican said 7 days to process order, and the rest of the retailers would have likely been too slow as well. If I can score one at Hershey, I will install it on the spot. I hope to get feed back from several people as they take a turn driving.
I am beat, and pretty freaking happy.
Krieger
Id like to see one track tested this summer and hear the results.
Dr Evil
You and me both smile.gif I will make a few to send to people for such testing, I expect.
I think I will run down and take a vid of a stock one with play, and the modified one both being used in the jig smile.gif Stand by!
CptTripps
Can't wait to see it this weekend!
I MAY have a short-shift kit from my last build somewhere. I'll have to dig through a few piles tonight to see what I can come up with.
(I really need to start digging through stuff tonight to see what I can/should take out there anyway.)
boxsterfan
Awesome thread!! Would love to reduce the bowl of soup shifting feel in my side-shifter. Looking forward to a "production" model. :-) popcorn[1].gif popcorn[1].gif popcorn[1].gif
Dr Evil
Stock shift console with stock play:
https://www.youtube.com/watch?v=vb2lBHNAVk0
Modified smile.gif It was not harder to shift, just harder to line up with one hand now that slop is significantly reduced.
https://www.youtube.com/watch?v=P2SmpwTKYvY
Dr Evil
Technical difficulties with imbedding....wait one. (fixed)
'73-914kid
Yepp, I'm sold. Love the lack of slop. Sign me up!
CptTripps
That's bad-ass dude. Going to be a HUGE hit.
Black22
Dr Evil
I am feeling pretty good. Cant wait to drive it.
Doug, that would be friggen awesome!
Mblizzard
I am in for this!
Dr Evil
Where as a Rennshifter addresses the problem at the end of the chain, my solution will address it at the source and will be far less.
The only thing that I see as a potential for loss of optimal is the in and out play on a box where I have not adjusted the internal rods. If your rods are cocked ever so slightly, then you can run into binding. The easy cure would be to allow for more slop in this direction. Thus, it is looking like two sets will be offered: I install and custom fit one to your box, or I send you a unit to install that will be only slightly less awesome, but still a huge improvement.
As for the 911/912/tail folks, I am still working on ways to get rid of the side to side play in the stick. The anatomy of the mechanisms are different enough to not allow for the simple solution done to the side shifters. Probably need to make a special shifter ball end.
bulitt
Remind me how difficult it is to pull this rod out for shipping confused24.gif
914werke
QUOTE(Dr Evil @ Apr 16 2014, 09:24 AM) *
Are you suggesting that it would be either or of these solutions or would combo of the two allow the heavens to open and beams of light to shine forth from your shifter?
bulitt
QUOTE(rdauenhauer @ Apr 16 2014, 01:06 PM) *
JWest
The RennShift addresses the large amount of friction in the factory shifter and adds the gate springs that 99% of manual transmissions are blessed with from the factory. Reducing play is only part of the picture. Lots of weak areas in the shift mechanism - have to hit all the links as each improvement makes the next one the weakest.
Edited out the drama after a good night's sleep...but you still get to see it quoted...
ablesnead
QUOTE(JWest @ Apr 16 2014, 01:44 PM) *
QUOTE(Dr Evil @ Apr 16 2014, 11:24 AM) *
I don't see a slam on your product at all...I have seen before a defensive attitude in your response to perceived criticism ..I have seen great respect and appreciation from this site chatter for the rennshift..I am saving to purchase one soon...in in hobby viable solutions at a cheaper price than currently available will generate buzz...its not automaticly a knock on an already existing product .You and Jake get some skin thickner
Rant warning - sorry - you brought me into this...
I find it interestingly sad that many 914 owners feel the need to attack and put down those that produce parts specifically for these cars. I don't belive that I have EVER wronged anyone in a sale, yet you guys seem to treat me like the evil corporation after your money. I'm not StuffMart producing crap in China to put others out of business...
As for the price, this is a very small market. If not for the similarities with the 911 version, I would not be able to make this a viable product at all.
I did make a cheaper version for a time - the RennShift Jr. Most of the features of the RennShift for half the price. Sold 2 in as many years. Price is not everything...
Sorry, but I feel that you guys go out of your way much too often to alienate rather than support those that make products for these cars (and it's not just me).
If you can make this product work well then it will be a good combo with the RennShift. Good luck with your progress - when I tried this mod I found that the pattern was overly constrained so it took too much deliberation follow a square corner from gear-to-gear. Much like driving with a true gated shifter in a Ferrari - cool, but kind of a pain.
Dr Evil
Dude, unclench.
1- Renshifter is $500+, FACT
2- It addresses the issue at the END of the shifter circuit, FACT
Did I post derogatory comments about your product? NO. Do I own one? YES. Have I always posted uncompensated positive reviews when asked about it? YES. So cool you jets.
I merely wish to build a better mouse trap. My enhancement, which has yet to be tested, if it works as I anticipate, will fix the problem at the source and cost a fraction of a Rennshifter, FACT. Also, stupid easy to instal.
If you dont like ingenuity and want us all to just accept what is already out there, then you are mistaken. My concept and potential product in no way diminish what you make and sell. For all we know, the Rennshifter will still be the superior solution, and I may not sell any of my units, and they may work stupid well in concert together. I dont know, that is why I am testing it and trying to refine it.
I in no way was making a personal attack on you, Rennshifter, or any other vendor. I have supported your product to people in public and private, and I only use it as a benchmark to beat.
JWest
OK, unclenching performed - do I need to send a copy of my insurance card or is the first time medical advice free? confused24.gif biggrin.gif
Evil, carry on and make this thing work!
Dr Evil
Drama off:
So, to change this unit you would need to drain the oil, remove the external shifter rod, transmission in neutral, remove two nuts, pull the console, install the new console, reassemble everything, put new oil in, adjust shifter.
As for 914 stuff, this is pretty easy.
If I installed it on your rebuild, nothing different would need to be done when installing.
Sooo, on that note, I am about to finish the assembly of the test/raffle box and then drop the trans out of my car and maybe put the new one in depending on how tired I am. I was up tweeking until 3am with this and the transmission, back up at 830 and feeling it.
Dr Evil
QUOTE(JWest @ Apr 16 2014, 09:40 PM) *
QUOTE(ablesnead @ Apr 16 2014, 06:47 PM) *
It's not excessively defensive when my product is called out by name...I had no business on this thread until that point.
Again, sorry for the rant - I've just seen too many sideways comments about good vendors (not the known bad ones) without real product feedback or useful criticism and I'm piling this on, not accusing the Dr. of doing this.
I know how stressful it can be, Big Guy. Niche market, good product at a great price that is still not cheap enough for the masses makes it even harder. I still think your stuff is titts. smile.gif
timothy_nd28
