Eric_Shea
Dec 12 2005, 04:59 PM
New Address:
372 W. Winchester
Murray, UT 84107
855-786-7101
Eric_Shea
Mar 12 2006, 10:20 PM
A-Calipers as well...
MoveQik
Jun 23 2006, 03:43 PM
Major props to Eric. Got my calipers today. I happened to be at the shop that they were shipped to when they arrived. Shop owner was very impressed with the quality and the price.
tomkirkcis
Nov 11 2006, 08:03 PM
are stainless steel pistons available? are they recommended?
Eric_Shea
Nov 13 2006, 11:18 AM
There are no stainless pistons available for -4 calipers.
There are stainless steel pistons availble for -6 calipers however.
Are the recommended? Not by me. I have seen "VERY" few steel pistons fail because of rust issues. 99.999% of all the steel pistons are reusable in this application.
The only place I think stainless steel pistons are valid are in S-Calipers. The factory plated the pistons for the S-Caliper and 80% of the time, those plated pistons flake where the seal rests against the piston. (I think there's a picture of that in this thread).
914werke
Nov 15 2006, 03:16 PM
Eric in the R. application where you space out your stock /4 calipers with your "V" kit use the vented 911 rotor & your spacer, do you need longer studs in the hub?
Eric_Shea
Nov 15 2006, 04:22 PM
It's "advisable" but right on the edge. The rotor spacer will move the rotor out 5mm. Our standard studs are longer than the 45mm factory studs but not all that is "engagement".
I would probably move up to the next stud length at that point. In fact, that's what I did with my RS replica when I used the 7mm factory spacers for the back.
914werke
Nov 15 2006, 06:07 PM
Bummer
mills914/s
May 3 2007, 08:34 AM
Eric,
Your great my calipers turned out great Im glad you could fix what my pet Monkey broke.
Thanks alot. Hope to see you at the WCR
Seth
trapper
Jun 18 2007, 04:58 PM
Beautiful work Eric! I had the car to the track and they performed as well as they look.Click to view attachmentClick to view attachment
charliew
Aug 10 2007, 05:58 PM
Eric how long does the cad plating hold up on a car thats kept inside and kept clean? Do you think the ceramic coating will last longer? Thanks
Charlie
Bertus
Oct 30 2007, 11:39 AM
Just wanted to say thanks to Eric. I won a free rear caliper rebuild at last years Fall Foilage Classic that Eric was kind enough sponser. He helped walk me through the installation and answer all my questions (even the dumb ones!).
The calipers look great, and work great!
Thanks Eric!
Bert
purple
May 9 2008, 08:51 AM
I got this whole setup from Eric, it's bitchin!
type47fan
May 31 2008, 01:56 AM
Eric,
Would you like to play around with rebuilding these? I will send you a set to evaluate. At first glance, they look pretty simple. PM me if you're interested.
Thanks,
type47fan
May 31 2008, 01:58 AM
. . . last one . . . . I'm thinkin' clear anodize . . . .
6freak
Aug 12 2008, 11:33 AM
QUOTE(Eric_Shea @ Jan 13 2005, 04:36 PM)
REAR BRAKE CALIPER REBUILD SERVICEA stock 914 brake system was state of the art for it's day and still to be revered today...
if it's working properly. Are your rear calipers doing their job? Are they even working at all? When was the last time you set your venting clearance? Do you know if your pistons are frozen or not?
It seems as though these 30 plus year old 914?s are chewing up and spitting out their rear calipers at an alarming rate. Because of the unique integrated hand-brake assembly, the
ATE 914 caliper is a tricky little animal to rebuild. There are springs and clips and little sausage shaped things in there. If fumbling around with this kind of stuff isn't your ?cup of tea? then I have something for you. I offer a caliper rebuild service. Here's what you get:
* Disassemble caliper
* Bead blast caliper to bare metal
* Replate with factory yellow zinc plating (silver available on a special order basis)
* Hone the cylinders
* Polish Pistons
* Install piston and adjuster screw rebuild kits
* Lube and reassemble the caliper
Pricing is $349.00 per pair ($174.50 each) plus core and shipping.
I only sell these in pairs. **UPDATE**
Shipping is now a flat $8.95 for Priority Mail to anywhere in the continential United States. For international orders you can still use the USPS link. Boxed weight is 16lbs. You can calculate postage from 84092 using this site
USPS Shipping Calculator then click the button below to purchase now.
If you'd like to know more about the process or want to try it yourself, here's a thread for those
Do-It-YourselfersPMB Performance - 372 W. Winchester - Murray - UT - 84107
Call 855-786-7101 Thanks Mr Shea the calipers look great
PeeGreen 914
Aug 13 2008, 07:28 PM
Eric does very nice work
carr914
Aug 14 2008, 07:56 AM
Eric's handywork..
..Almost too Nice to put on a car
T.C.
Click to view attachment Click to view attachment
Eric_Shea
Aug 19 2008, 11:20 AM
Thanks guys!
Happy braking!!
JazonJJordan
Jul 25 2009, 09:28 AM
Hey Eric!
Still helping us stop in style? Your work is beautiful. Do you offer a 911 caliper set to replace the front/rear with vented/drilled rotors? Thanks- jzn
Eric_Shea
Aug 4 2009, 12:07 PM
eyecolor
Oct 4 2009, 09:57 PM
Dear Eric
I am sending you a pair of rear calipers for a rebuild.
Is a business check OK or do you prefer paypal?
George Ozer
Boothwyn, Pa
Eric_Shea
Oct 19 2009, 10:39 AM
Check is fine... you can even order them online:
http://www.pmbperformance.com/calipers/html
eyecolor
Nov 23 2009, 02:56 PM
Eric
Just got my rears with the pads and thanks!!
The fronts are on the way. Let me know when you get them, I forgot to put any name inside the box.
George O.
Wilmington,DE
or Boothwyn,Pa
Dr. Evil has been saying nice things about you
Goose
Jul 16 2011, 05:18 PM
Eric,
Are you still rebuilding 914 calipers? I need at least the rears done on mine.
Thanks,
Andy
davep
Jul 16 2011, 05:59 PM
He certainly is. Just follow the link in post 76 above.
RS22b
Aug 16 2011, 10:42 AM
Just ordered a set of rears so i can at least drive my car this fall!
Can't wait for them to come in!
RS22b
Aug 16 2011, 12:12 PM
Just removed my rears. They are ready for shipping back.
RS22b
Aug 16 2011, 12:13 PM
Harpo
Sep 9 2011, 06:56 AM
I have a carrera frt end that I will be installing in my 75 914. Instead of the carrera calipers can I use the "S" calipers? I know that they are both 3.5 inch spacing but will the caliper line up with the rotor? Also the "S" calipers are missing the crossover line connecting the right & left pistons on the calipers. Is that part available?
Thanks
Harpo
Eric_Shea
Sep 15 2011, 05:54 PM
Kinda and yes. They will bolt on to a 3.5" strut. The problem you'll have is the width of the Carrera rotor (if you decide to use them).
Let me expound upon the rotor. At 24mm I don't think it's needed in a 2,000lb. car. That said, you can use the 20mm rotor and the S-Caliper will slide right on. The 24mm rotor is heavier as well. This is the absolute worst place to add weight... rotating mass. So, my recommendation is to yes, use the S-Caliper and use a 20mm rotor.
Yes, we have stainless steel replacements for the compensating lines. They're $38.00 for the pair.
Eric_Shea
Sep 15 2011, 05:57 PM
BTW... we have had a set of S-Calipers cut for the 24mm rotors but I really recommend against that.
https://www.facebook.com/media/set/?set=a.4...34e1&type=1
RS22b
Oct 2 2011, 12:51 PM
Eric how do i get the inner adjusters out of my old rear calipers? Only 1 caliper has one of those adjusters. Is this an issue? Can i buy another adjuster from you? or 2 new ones for that matter?
Thanks!
Billy
ConeDodger
Oct 25 2011, 09:24 AM
Speaking of rotating mass, is PMB going to offer carbon fiber rotors for 914's?
tongue firmly in cheek...
