QUOTE(mramber @ May 1 2014, 05:40 PM)
I am in the same place. forgive me if this sounds dumb but I'm somewhat new to welding. When you say weld them up, what is the best way to do this without blowing a bigger hole? I'm using a MIG welder and I have been practicing. Do you put some "backing" metal on the inside and weld from the engine compartment, then grind and smooth in the engine compartment for a nice finish (which is what I want to try)? Can a good welder start at an edge and fill the hole without burning through and making it bigger? Maybe I should drill some holes in sheet metal and practice welding them shut...
With a length of copper piping, bend over end and flatten. Have a helper hold it from the engine side to use as a backing. The welding won't attach to the copper.
Dave
