75 2.0
This is a repost of sorts.
Turn signal / hazard relay buzzes with power on (key in on position). Red brake warning light is solid.
If I use the turn signals, the unit "clicks" as you would expect. The turn signal indicator blinks in time, as does the red brake warning light.
If I turn the hazard lights on, all works as expected. The red brake light also blinks.
The red brake idiot light is the "B" light near the temp gauge.
I don't know if the "B" light should blink when the turn signals are used. I think not, so the fact that they do and the fact that the buzzing and solid red light seems to indicate something, but I don't know what or where to begin to start to troubleshoot.
I don't have another relay to try, the one I have is new, so I'm leaning to something else that is causing that red light to stay on and the buzzing.
Thanks,
Len
