jwalters
Jan 15 2005, 10:39 AM
Hi guys, once again--at work right now but not allot going on---I am replacing my rear trunk floor and was wondering if anybody else just lapped the new floor right over the old crossmember-or if you actually disemboweled it and put the whole new schebang in......
Thanks in advance....
IronHillRestorations
Jan 15 2005, 01:23 PM
All of the rear trunk pans I've replaced were only rusted rear of the dogbone shaped crossmember. What we did was to cut out the spot welds that attach the pan to the rear panel and the inner fender. Then along the rear flange of the dogbone, where the pan is spotwelded to the dogbone, you carefully draw a line that centers the flange and cut through the pan with a cut off wheel. This way you've got a lip to hang the pan on. We leave a 1/16" gap and weld the three pieces back together. I've got a 220v spot welder, so that's how the rear of the replacement pans are welded back on here, but you can punch or drill holes and plug weld that.
Does this make sense? I'm not sure if I've got pics, but I don't think so. The place you purchased the pan from should give you tech support on this!
SpecialK
Jan 15 2005, 04:24 PM
Gotta do the same repair when things thaw around here (70F Thursday
, 12F today
), all pics are helpful and appreciated!
Andy - Love the "rearview" on that car of yours!
SpecialK
Jan 15 2005, 06:49 PM
Hard to tell from the pics, but is the rear of the trunk floor just tacked in every couple of inches? Or did you "connect the dots" and weld it in solid?
